Thread: GEET Reactor
Old 11-22-2012, 01:09 AM   #81 (permalink)
oil pan 4
Originally Posted by RustyLugNut View Post
What is the thermal efficiency of your diesel engine? 35%? 45%? How about some of the large power generating diesels and their 52% indicated thermal efficiency? Now, you will admit that with some co-generation, up to 60% thermal efficiency is possible - and beyond. Is that a unicorn pipe dream?
The kubota engines run at about 14% thermal efficiency at 2kw load.
The problem is nothing is going to make them much more efficient when spinning at 1800RPM at 1/3 load.
It doesn't matter how many GEET reactors or HHO generators you bolt on to it, they will do nothing to get around the pumping losses.
A turbocharger would be the best thing for them.
You have already mentioned the turbocharger as a means of trapping lost exhaust heat. Most good turbochargers can increase thermal efficiency in the neighborhood of 5%.
Seems to have given me a +2mpg boost just driving around town.
How about thermoelectric recovery?
Its not unicorn material at all.
I have priced it and its out of my price range, if the units I saw are even for sale yet.
