Originally Posted by serialk11r
Wide open throttle is pretty efficient, come on, you're an ecomodder :P
No its not because at WOT you are running the engine on fuel enrichment, you would want to run at the maximum throttle opening that permits stoichiometric air/fuel ratio. Maybe thats 80% or 90%, I really dont know the point, but WOT is not where its at for FE on a stock production gasoline engine.
