Old 11-23-2012, 03:08 AM   #96 (permalink)
Nobody123
turbovr41991, I have a question for you if you don't mind.
From the other thread:
Originally Posted by turbovr41991
I have a 5th gen VX (1994) trans in my sixth gen CX (1997).
I'm trying to do this exact swap.
What t-bracket did you have to use?
Were you able to use the stock 6th gen t-bracket or did you have to use the t-bracket from the 5th gen? I know that the rear mount is the same between the 5th and 6th gen, but which t-bracket did you end up using?
What about the upper mount? The 5th gen has a 1-piece mount vs. the 6th gen has a 2-piece mount. How did you get this to work?
And which VSS did you end up using?
Thank you for your help.
