Old 11-23-2012, 05:19 PM   #98 (permalink)
Nobody123
Originally Posted by turbovr41991 View Post
I will check when I get home but I am pretty sure everything I used was 6th Gen. Both T bracket and upper mount. I don’t remember the VX trans coming with a bracket, but I could be wrong. It has been a while as this was the first mod I did to the car (bought it with a bad transmission so it has had a VX trans nearly since I bought it.) I am out of town currently and only have one civic to compare against right now. Once I am home I can compare against the rusty HX (now D15Y7 powered) to be sure.
I also suspected that the t-bracket and upper mount bracket were the same, but without having done it I won't know for sure. I will try and hope that it fits.
I also used the stock CX VSS. Speed reads slightly faster than the actual speed by 2-3 mph. However, the odometer miles are actually about .5 to 1 mile LOWER than what the gps says in distance traveled on a full tank of gas. That makes no sense to me… I guess the stock cluster is inaccurate to some extent on speed. I have fine tuned my MPGuino to be dead on with the GPS speed which is a much better method.
Thank you for your comments.
