Old 11-24-2012, 10:24 PM   #22 (permalink)
ECONORAM
halos.com
ECONORAM - '07 Dodge RAM 1500 QC SLT flex-fuel
90 day: 18.16 mpg (US)
the Avenger - '08 Dodge Avenger SXT
90 day: 27.06 mpg (US)
Send a message via Yahoo to ECONORAM
Originally Posted by Sven7 View Post
Do an air dam and add pans under the engine bay and behind the rear axle. The minimal gains you're likely to see by doing a full belly pan instead of the former aren't worth it in my opinion. Use only existing holes when mounting stuff.
Roofing tar sounds promising but I still wouldn't chance it.
I used the same principle on mine. Avoided drilling any holes in the truck; used holes or bolts already in place, fabbed brackets to support the panels from L-angle metal (flat straps flop around too much to suit me). Had pretty good results with the first half of the truck covered. Did a full belly and didn't see much difference.
Be sure of what bolts you loosen though. I loosened two that required a new front end alignment. WHoops.
