Old 11-24-2012, 10:34 PM   #1 (permalink)
Diesel_Dave
Diesel_Dave's Avatar
White Whale - '07 Dodge Ram 2500 ST Quad Cab 2wd, short bed
90 day: 37.68 mpg (US)
Best way to fix a slow leak
I've got one tire that's got a slow leak in it. Usually I pump uo to about 75 psi, and check pressures about once a week. Ususally that tire has gone down to about 60 psi. It seems to be getting a little worse as time goes on. The tire's getting low on tread so it'll be due for a replacement before too long anyway, so I'm not sure if it's worth going into the tire store. It's just getting a little tedious to pump up every week.
Does anyone have experience with using Fix-a-Flat or any of those other produts? I've heard mixed reviews. Any other techniques for fixing slow leaks?
Diesel Dave
My version of energy storage is called "momentum".
My version of regenerative braking is called "bump starting".
1 Year Avg (Every Mile Traveled) = 47.8 mpg
BEST TANK: 2,009.6 mi on 35 gal (57.42 mpg): http://ecomodder.com/forum/showthrea...5-a-26259.html
