Originally Posted by elhigh
Plumb the dump loop to your biodiesel processor. Why pay for heat when you have a convenient fusion reactor beaming power directly to your house?
In the works. there is no hot water plumbing anyplace near where the bio processor will live. I'm definitely planning on using it at lest for drying. I will however need a circulation pump, any ideas?
Damn I've got to build one of these things. And the place I want the water heater is under the house. Sure, it'd put it outside of the insulated envelope, but where I live winters aren't that bad, and even if I wound up dumping some amps into it once in a while, it'd still be way ahead of dumping amps into it all the time. It'd also take it out of the air conditioned space, and that's more important to me.
There is very little heat coming off of the tankless heater; it is in my old insulated water heater cabinet, and it isn't warmer than outside of it (was blistering with propane.
IMHO not worth moving . . . .
