This weekend I worked on a grill block. The pipe insulation has been in place for a few weeks.
The small area of the upper grill that was not yet blocked
Complete upper grill block with partial lower block and fog light cover. I did only one fog light cover to see how it looked. I'm not 100% sure if I will keep the fog light covers or not. I will probably add an identical lower block to the other side so 2/3 of the lower grill will be blocked. The lower grill block is choroplast connected with zip ties.
