The truck wakes used to push my little car around until I added a chin air dam for down force. In your case, the angle of attack being a few degrees more negative and slightly rounder sides may do the trick.
fortunately this fairing will have much better rounding at the front and sides than my last.
There are tons of books and articles on composite construction available. Try recumbents.com first.
Thanks, I'll check it out.
