Old 11-26-2012, 03:07 AM   #120 (permalink)
TheEnemy
The road not so traveled
TheEnemy's Avatar
The Truck - '99 Nissan Frontier xe
90 day: 25.74 mpg (US)
The Ugly Duck - '84 Jeep CJ7 Rock crawler
Sure, since there's about a billion years to look at. Now ask yourself whether those extremes would have been pleasant times to live in. Most relevantly, we have an instance of global warming which, as best we can tell from the evidence remaining after ~250 million years, was due at least in part to the burning of large coal beds. That event - the Permian/Tertiary Extinction - killed off some 70% of terrestrial vertebrate species. Being that I am myself a terrestrial vertebrate, I don't care for the prospect.
In all reality they only have conjecture as to the cause, with several theories including the one you listed.
The rest of the non-CO2 related temperature excursions are largely irrelevant (except as they tell us things about the climate in general), because we KNOW beyond any possible doubt that humans have increased atmospheric CO2 concentrations beyond their normal levels.
Yes, there is no real argument there.
But the models ARE pretty much spot on. As for instance Hansen's "Scenario B", which comes fairly close to what actually happened - and comes closer still if you go back and plug in actual CO2 increases instead of the guesses made back in the '80s. And yes, I know you can find some denialist sites that claim Hansen was wrong. If you examine their claims, you'll see that they are lying.
I have only seen one that was even remotely close, and the authors admitted that they still had lots of work to go. They had CO2 and solar forcing at equal ammounts.
Speaking of Hansen, why have outside observers had to correct the temperature data he has put out on several occasions for being too high? Human error would dictate that such errors would be either higher or lower but rarely would such errors consistently be the same.
Not true. Sure, the above denialist sites have tried desperately to use a few out-of-context quotes and such to create an impression of a lack of credibility, but the only people who believe them are the confirmed denialists.
Why did it need to be mentioned? You had one party running a pair of (excuse my language) effing creationist idiots, backed up by Senate candidates mouthing off about things like "legitimate rape". And notice that they lost :-)
Of course anything can be improved, but if you've just fallen off a cliff, do you really care that a detailed model that takes account of the variability of air resistance with temperature predicts you will impact the ground in exactly 5.328 seconds?
What would it matter if a model said I was falling off a cliff if I am a mile away from said cliff?
So why should Mann have to release his work to gratify denialists? Especially when their primary motive seems to be to keep him and other climate scientists so busy responding to their harassment that they won't be able to do actual work? Plenty of similar data is available, and when analyzed shows similar results, which is a far more robust confirmation than picking apart one study that you disagree with.
He refuses to share his work with even other climate scientists if they do not already agree with him.
Plenty of open source climate code out there. Look up EdGCM, for instance.
I will be looking it up.
Sure, he thought that. Then he actually looked at the data, discovered that he was wrong, and was honest enough to admit it.
