Old 11-26-2012, 04:15 AM   #5 (permalink)
ChazInMT
Aero Deshi
ChazInMT's Avatar
MagMetalCivic - '04 Honda Civic Sedan EX
Last 3: 34.25 mpg (US)
Though it will need to do so for a shorter period, resulting in the same work done and the same edges fuel used, right?
What? No, the alternator generates DC power, whether it runs at 1,000 or 8,000 RPM it will deliver the required amps at 14 volts or so to keep your car supplied with electricity. Speed doesn't affect its ability to create power, for the most part, very low rpm's being the exception.
What Frank was so astutely referring to is the fact that the alternator has bearings which are not perfect, the higher speed it runs, the more power it takes to overcome the friction to turn the bearings. As well, since the rotor of the alternator does not exist in a vacuum, air friction plays a role as well, but mostly, there is a cooling fan on the beast, and the faster it spins, the more power it needs.
The cooling fan in fact, being a pump type of thing, actually obeys a cube root function in its power requirements, so an increase from 1,000 to 8,000 RPM results in a 8³ increase in power required or 512 times the power is required at the higher RPMs to run the fan, good thing it starts out as a tiny fraction of a horsepower to turn the fan.
