Old 11-26-2012, 01:34 PM   #29 (permalink)
arcosine
Master Ecomadman
arcosine's Avatar
sc1 - '98 saturn sc1
Team Saturn
90 day: 43.17 mpg (US)
rans - '97 rans tailwind
90 day: 28.25 mpg (US)
red bug - '00 VW beetle TDI
big tractor - '66 ford 3400
90 day: 58.42 mpg (US)
RV - '88 Winnebago LeSharo
90 day: 16.67 mpg (US)
No special tools need for tie rod ends, I suppose one could use a spreader, but I just use a hammer and a little heat, if necessary. There is probably a you-tube video on it. Never had an inner tie rod go out.
Jack up the wheels, if the play is for-aft ( steering direction) its the rod end, if its up and down it's the ball joint (s) or bushings. I had a rear upper ball joint break in my 87 honda, it was on top, right above the tire. I lashed it together with bailing straps I found along the road and made it home.
- Tony
