Old 11-26-2012, 03:07 PM   #19 (permalink)
Diesel_Dave
Diesel_Dave's Avatar
White Whale - '07 Dodge Ram 2500 ST Quad Cab 2wd, short bed
90 day: 37.68 mpg (US)
Originally Posted by CapriRacer View Post
I am hoping you realize that the tires are different. #385 - the OE tire - is the tire as designed to meet some OEM's specs, where #149 - the Replacement market tire - was designed for the replacement market. They are NOT the same tire.
It is common for tires to start out as a Replacement market tire, then a program to supply a tire to an OEM comes along and the tire gets redesigned to the OEM's specs - which are a lot about RR and not much about treadwear. The Replacement tire would be completely replaced by the OE tire.
It is also common for the opposite to happen - OE tire first, then when the OEM no longer wants the tire, the tire gets changed to Replacement standards - which means a better wearing tread compound.
So if I want OE tire (#385) is there any way for me to get it?
If I just go looking for a Bridgestone Dueler Alenza HL 265/70R17 tire, will I just automatically get the replacement version (#149)?
Diesel Dave
My version of energy storage is called "momentum".
My version of regenerative braking is called "bump starting".
1 Year Avg (Every Mile Traveled) = 47.8 mpg
BEST TANK: 2,009.6 mi on 35 gal (57.42 mpg): http://ecomodder.com/forum/showthrea...5-a-26259.html
