Old 11-26-2012, 03:45 PM   #10 (permalink)
topcat
topcat's Avatar
Celica VVTI - '05 Toyota Celica GT VVTI
90 day: 41.89 mpg (US)
Hey BackroadBomber,
That's great that you are going to give it a try. I don't think you will see instant results with this, only under those limited set of circumstances when pre-detonation would occur. As has been pointed out, that is probably more likely if you have a grille block or other mods to keep the engine hot.
@KSA8907, disconnecting the battery is required after installing the new plugs to clear the ECU of those situations it has already learnt when pre-detonation occurred with the old plugs. i.e. to give it a fresh start and learn the new parameters.
