Old 11-27-2012, 12:17 AM   #35 (permalink)
Gasoline Fumes
Too many cars
Gasoline Fumes's Avatar
CRXFi - '88 Honda CRX XFi
Insight 256 - '00 Honda Insight
Gen-1 Insights
Insight 5342 (no IMA) - '00 Honda Insight
Gen-1 Insights
90 day: 66.3 mpg (US)
Originally Posted by PaleMelanesian View Post
I have a long hill I tackle every day. It's about almost 1/2 mile long, ~3% grade. It's shallow enough to gain speed in 5th gear. I note the change in trip mpg from bottom to top each day. It's at the same point in my commute, so that's a consistent mark. The best approach, that loses the least mpg, is the old "slowest speed in top gear". If I start the hill at 25 mph in 5th gear (1000 rpm), hold 80-85% LOD, I accelerate to the 45 speed limit at the top, with the least mpg lost. Other gears, higher starting speed, lower LOD, all give worse results.
But climbing the whole hill at 25 MPH would be even better, right? I usually try to lose speed up hills, not accelerate. With no instrumentation, I'm just guessing. I've been thinking about this post every time I climb a hill.
2000 Honda Insight
2000 Honda Insight
2000 Honda Insight
2006 Honda Insight (parts car)
1988 Honda CRXFi
1994 Geo Metro
