Old 11-27-2012, 08:00 AM   #4 (permalink)
Daox
Probably the easiest thing to do is pull the chip off the board and stick it in another arduino board for programming. Otherwise you'll have to wire up some pins or a connector that will connect up to a FTDI board so you can hook it up to the computer.
