Thread: Helium
Old 06-12-2008, 04:37 PM   #11 (permalink)
ConnClark
DieselMiser
ConnClark's Avatar
Das Schlepper Frog - '85 Mercedes Benz 300SD
90 day: 23.23 mpg (US)
Gentoo320 - '04 Mercedes C320 4Matic
90 day: 22.44 mpg (US)
Actually, if you could keep it from leaking out, helium in the tires would work better than nitrogen because it behaves more like an ideal gas. Personally, if cost wasn't an issue, I would be running neon in my tires. Argon though heavier might work better than nitrogen too.
weight of gas by liter at one atmosphere at 0 degrees C
nitrogen = 1.251 grams
neon = 0.8999 grams
argon = 1.784 grams
