If nothing was any different with the ignition turned off then your vehicle uses DFCO. If it decelerated at a different rate or pitch with the ignition off then it does not use DFCO. Do not forget to start your engine back up!
Do not try to start your engine back up (with the starter motor) while the car is moving and in gear. Just putting the key on run will cause the engine to "restart"
I know YOU know this, but someone else reading this site might not.
