Thread: Chevy Spark EV
Old 11-29-2012, 01:08 PM   #7 (permalink)
tjts1
Originally Posted by Old Tele man View Post
...sorry, but 0.325 Cd is NOT very good aerodynamics...the much bigger VOLT is around 0.30 as I recall.
You need to read up on what coefficient of drag means because you're statement is complete nonsense. Trying to compare the Spark to a Volt or EV1 is ridiculous. Drag coefficient has nothing to do with size. A full size car has the same drag coefficient as a 1:18 scale model of the same car. 0.325 is excellent for an upright city car with 5 seats and very short length. Long sedans will always have the CD advantage over short hatchbacks.
Another difference between the Spark and MiEV is the battery chemistry. The MiEV is using lithium titanate versus the Spark's lithium iron phosphate. I believe lithium titanate is better suited to abuse (fast charging) than lithium iron phosphate. However, the A123 nanophosphate technology should narrow if not eliminate that gap. The townside of lithium titanate I believe is that it is not as energy dense thus the battery is larger and I'd imagine heavier.
After the Fisker debacle and A123 in bankruptcy I wonder how many battery packs they can actually supply. The original announcement was for 5000 cars but I wouldn't count on them.
