Wire had a brake in it. The computer showed -40 (according to Ultra gauge) MAF is separate but the temp probe samples the same air and the computer corrects the MAF for intake air temp(this was on a the Ford though most MAF systems are similar). If your scan gauge is showing a close number I would not suspect a problem there.
The smell of fuel is pretty indicative of a very rich mix.
Learn from the mistakes of others, that way when you mess up you can do so in new and interesting ways.
One mile of road will take you one mile, one mile of runway can take you around the world.
