Originally Posted by arcosine
Not quick to blame, I had one a long time ago. You can reduce the friction all you want, but if the heat escapes through all that combustion chamber surface area, you loose.
Yea well, either way doesn't hurt to have double digit percentage increases in mechanical efficiency AND combustion efficiency
![Smile](/forum/images/smilies/smile.gif)
(Mazda is undergoing a similar fuel efficiency leap lol)
But don't hate on short stroke engines, the BMW S65B40 for example is a beauty. Piston and head design matters more than dimensions anyways. Mazda Skyactiv engines may have good bore/stroke ratio, but the extremely high compression ratio usually gives the combustion chamber a bad shape, so they gave it that rather deep piston bowl. In fact the low compression ratio on the EJ engines probably helped the heat rejection (at a greater efficiency penalty of course).
