Thanks. Tomorrow i will drive a 500kms run. 2 Persons. Half the way back with 80kgs load. A set of winter wheels/tires.
I will use hypermiling techniques again. The last 2000kms i drove just normal between 33.8 and poor 24.8 MPG
In Germany it is allowed to remove the right mirror as long as you have an interior mirror and one on the left side. I would rather have the right mirror of an Golf Mk IV Cabriolet. Fits perfect and it is much smaller. I don't like the driving without.
Your LPG ECU needs to be programmed at a lower switching temperature. Visit the garage where it got installed. They can do thet easily. Or get an interface for the ECU and do it by yourself
The car has an O2-Sensor.
