Old 12-01-2012, 12:57 AM   #11 (permalink)
oil pan 4
Originally Posted by serialk11r View Post
Uh, that is definitely not a 'typical' electrical load on a car, unless you have a 2000 watt sound system. I did a bit of research into this trying to figure out how whether off the shelf thermoelectric generators could generate enough electrical power for the car. 300W is a typical electrical load, comes out to maybe 0.75hp at the alternator.
Don't forget about the drag produced by the little fan in the alternator while its spinning at 3 times crank shaft speed.
