Old 12-01-2012, 04:43 PM   #1 (permalink)
RatherDashing
94 honda civic vx issues
last month i was driving a 1997 buick park avenue gas hog with bout 171k miles on it and i missed my civics too much and managed to trade it for an unmolested other than riding on steelies 94 honda civic vx and it just hit 130k miles on it.
its got quite a few issues with it of course some i know of others i dont.but i really wanna get this fixed up and be able to get that beastly mpg with it. while driving and shifting in between gears the rpms most of the time will stay high and i shift at bout 3k rpms.they will most of the time stick and take a while to drop and/or they will drop and reach almost 0, the car shutters a little then they come back up.once in a blue moon the car will stall from it. this is one of the biggest issues im having and am not sure where the cause could be at if its the IACV or the TPS or something else im unaware of.
the plug wires i believe do need replaced they have a little orange powdery residue at the tips but im not positive if this wud fix that issue.also while driving at lower rpms the it has slight hesitation thats why i also suspected the wires.But the previous owner was telling me about a tube underneath the intake manifold thats used during lean burn mode that probably collapsed but i cant find anything about this part online.
While shifting it doesnt grind at all but sometimes in gears when accelerating i will hear a grinding noise and from what iv been told its a throw-out bearing. the battery went out at one point and got that replaced.
i had to have the slave cylinder in the clutch replaced since it leaked all the way dry while driving and i cudnt shift it so got it towed to a shop cuz i had no other choice since i had no idea what was wrong with it. this shop is crazy and definetely never taking it there again. the first time they said they did a diagnostic on it and said it was fine after the clutch was worked on.
i drove it and it still had the same issues.i was questioning whether the tech even test drove it around the parking lot. took it back in they said the radiator had a leak on the bottom and wanted 400 to fix it.forget that im just gunna replace it myself radiator is easily under 100 bucks. then they said that they cleaned out the iacv and put it back on and the car was still having the bad idle problem so they quoted 400 to replace that. again screw that i cud buy a new one for 120 or so and just put it on myself i know about that.
this seems like a lot but to sum it up im curious if these sound like easy fixes and its worth fixing up. if the idling issue cud be something unrelated that i dont know of. also curious if an iacv from an 89 crx dx would work with it one of my buddies has one and i havnt tried that out yet. any advice would be much appreciated im still in the process of learning and fixing up hondas and enjoy it a lot
Last edited by RatherDashing; 12-01-2012 at 05:51 PM.. Reason: my bad paragraphs fixed
