Old 12-01-2012, 06:25 PM   #44 (permalink)
Varn
Do more with less
OD - '05 Ford Econoline
90 day: 18.64 mpg (US)
90 day: 49.71 mpg (US)
90 day: 28.08 mpg (US)
If I were in midland I too would find the outlet store for the insulation boards or find someone who has access to the scrap...
I remember reading about your lack of temperature when you doing the layup.
Tomorrow is supposed to be 65 in Missouri. I am going to do some body work on the VW.
Originally Posted by Weather Spotter View Post
I make my tail from fiberglass and all I had ever done was two patches on a canoe. I had no idea what I was doing as I tried doing it while the daily high temps were 25F out. Polyester resin takes 8-12 hours at that temp to become non tacky and be able to re-coat or sand. I used Dow Blue board foam (I am from Midland MI, home town of Dow) and the polyester only ate about 1/8" into the foam and then stuck to it hard. Here the big box home centers carry 3m brand "epoxy" (polyester) resin for about $35 a gallon.
Noah Webster, 1787
