Old 12-02-2012, 01:42 PM   #4 (permalink)
RatherDashing
Originally Posted by Ryland View Post
At 3,000 RPM your engine should sound like it's screaming and that something is wrong... a stock VX just doesn't sound right or happy with the engine going that fast, your gas mileage will also suck.
It sounds like the tube under the intake manifold that you are talking about is the PCV tube, that has a grommet that often drys out after 20 years and allows extra air in the engine, most of the time it just causes idle bounce, but if it's in poor enough shape that it's collapsed then it might also have a big hole ripped in it, or be gone all together.
Wud this tube be something i cud easily replace by lifting the car up jacks and getting under there? He did say it was a cheap part at autozone. it does start screamig at about 3k rpms.vtec-e works just fine.i was actually wondering if a cold air intake wud be better to hear the vtec more but from what iv read its best to keep the stock air intake and filter on there. Just when shifting the rpms have actually started to raise just a few lines then start dropping slowly.and i know that when shifting inbetween gears or neutral the rpms r supposed to drop down to normal idle. And yes gas milage is barely hitn 30mpg and that sucks for the vx
