Old 12-02-2012, 09:52 PM   #8 (permalink)
Ryland
Ryland's Avatar
90 day: 79.71 mpg (US)
Blue VX - '93 Honda Civic VX
Not everyone has found a PCV valve but some do... if there is a valve is in the lower part, not up top where you can get to it easily.
shifting when the shift light comes on is the best rule, otherwise shift before the engine starts to scream! 3k RPM is crazy! 2k RPM makes me twitchy and you have plenty of power at that speed!
So if you find a PCV valve then clean it out and you can get a replacement at the auto part store for a few bucks, but if you don't find a valve then don't panic, just make sure that the hose is in good shape and that the #3 grommet is soft and sealing well.
