A little trick i learned about the discount points here at stop and shop , If you only buy a small amount the points add up almost the same , i was only buying lunch there and would get 3 or 4 hundred points over time, even though the points are 1 per dollar, try it if its convenient, also the way the infrastructure is not a bad idea to have ten or so gallons around the premises,
