thanks!! yes i commute almost 700 miles a week so its going right into daily duty. i dont want to drive my 93 vx in the winter so ill substitute it with this 93 vlx til next spring.
I must have done somthing right. This morning i let it get up to operating temperature and it idled fine. I took it up the road and it ran fine. no problem with power output pulling out from a stop. no check engine lights. shift light worked as did my custom cruise control indicator. i have pics but i want to capture both the cruise and shift light coming on at the same time. i also tucked the wires underneath the dash in conduit. i took the downpipe from the new vx i picked up and it worked perfectly and even bolted up to the lx converter. im very pleased so far. before i can drive it long distance i have to install front calipers, brake master cylinder, and inspect it. look for pics by the end of the day.
