Thread: Tires and Rims
Old 06-12-2008, 11:02 PM   #20 (permalink)
abshnasko
so in conclusion (correct me if im wrong):
1. a larger rim + tire combo CAN be lighter if attention is paid, helping FE
2. larger rim is generally less aerodynamic and takes a wider tire, hurting FE
3. larger rim size means that more of the LRR tires will fit (possible negating the effect of #2?), helping FE
4. larger rim and OD reduces rpm's, helping FE
about a larger rim being less aerodynamic... would some of this be countered some if I installed dams in front of the wheels? Or would it have to be skirts...
