Originally Posted by Ryland
I lowered my first vx and didn't see any improvement in mileage the lowering suspension did however cause a rougher ride and seemed to wear out other parts of my suspension causing me to replace the spend about $600 putting it back to stock height, LRR tires do help, 45 to 50psi in the tires helps too, my next plan is light weight smooth wheels like the first generation Honda Insight used, there are a bunch of low rolling resistance tires in 14" sizes that would fit at that point where there are very few 13" options.
Other things that work:
Changing your transmission fluid (it takes motor oil or Honda MTF, NOT GL5 GEAR OIL, unless you like replacing transmissions!) I tend to use 0w30 synthetic motor oil in both the transmission and engine, it makes the transmission shift super smoothly and helps the engine with cold starting.
NGK v-power spark plugs are OEM and $10 for a set, they also work great, much better then expensive spark plugs, I have sets of 4 different brands of "high end" spark plugs that made my VX run poorly, the worst were the Bosch +4 and the Pulstar pulse plugs.
Thats my plan.synthetic oil change.ngk performance wires and plugs
and yeah most definetely not going to lower it. i read the same thing to online sumwhere some guy lowered it even just a little and everything started screwing up.the previous owner had a really nice set of tires on it before but wanted extra for them. but i really wanted to trade my 97 buick for it. so worth it in the long run especially got gas.
what are some signs of the head needing shaved down or something.iv looked inside the spark plug tubes(im very new to engine work only replaced spark plugs, wires and valve cover gasket before) and they dont seem as smooth as my d15b2 was. i remember hearing something about sending the head to a machine shop and them resurfacing it or something. how exactly does that work? i was also looking to see if i cud find a cheap head replacement and cant find one ANYWHERE
