shaving the head is a step below a full engine rebuild, $1,000 to have someone else do it is my guess, you can get a whole engine used and have someone install it for $1,000, so I don't think it's worth it at all! you would get your head shaved if you race and over heated your engine, if you ran it dry on coolant, or if you otherwise drive really hard all the time for 50,000 miles or more! you shave the head if it's warped, your engine is already a high compression engine.
