Originally Posted by Gealii
but if he plans on pulling a car he would need to upgrade the suspension. my bros f150 302(brand new upgraded suspension) was just about bottomed out pulling a 96 Taurus on a trailer. and the frame is not as strong which will also be taking quite a bit of abuse
If it was bottomed out someone wasn't balancing the car on the trailer correctly. IIRC you should have about 100 lbs on the hitch- then all you have to worry about is fishtailing.
