Old 12-05-2012, 08:44 PM   #16 (permalink)
Christ
Moderate your Moderation.
90 day: 45.22 mpg (US)
Originally Posted by snakub View Post
The hoods on some of the Firebirds come out to far into the front end would you have a year in mind for either the firebird or camaro? What do you mean by filler panels? Where would the flexible epoxy be used?
You'd be using the nose clip only. You'd have to cut it to adjust how tall it is to fit the front profile of the truck's nose.
The flexible epoxy is used to hold filler panels together between the areas you need to cut to make the nose clip taller.
Certainly not going to be an easy job, probably easier to start with a wood frame and glass it.
