Old 12-05-2012, 10:29 PM   #3 (permalink)
GRU
GRU's Avatar
silver bullet - '00 Honda Civic
90 day: 34.41 mpg (US)
I wouldn't do that, if you can't remember some things you should probably not read a paper on your steering wheel while you drive, especially when you're trying to drive in a new way...you might end up in an accident...
just remember, spend the least amount of time accelerating (foot on the gas)...in time you will realize how to do that without even thinking about it...
conserve momentum, so, if you're aproacing a red light but know it will turn green soon, start slowing down much sooner than other drivers and even brake hard if you need to, so when the light turns green you arn't stopped, instead moving (because you took your time getting to the light slowly)
