Hi Mike,
Sorry for the delay response and thank you so much for your help. I trying a battery charger/discharger similar to the MRC Super Brain 989 and see if I can recover the cell packs. I hope it work otherwise I likely need to run the car without the battery. Your charging system looks great except the investment is a little deep since it is very difficult to get parts and it is not easy to the vehicle here. The investment is hard to justify. However, if I could get the battery recover, I may want to get the simple charger that also developed by you.
Will update you the process. Regardless, your help is being greatly appreciated.
B/R
Wong
