Old 12-06-2012, 02:36 PM   #51 (permalink)
Allch Chcar
EtOH
Allch Chcar's Avatar
Cordelia - '15 Mazda Mazda3 i Sport
90 day: 37.83 mpg (US)
Originally Posted by radioranger View Post
I read where guys who run alcohol mixes in Go carts were adding 5 percent water to cool the combustion, may be some cash savings here for the daring !
You do not want to add water to Gasoline though, the fuel pump will pick up slugs of water and make it run like crap. Now people do use as little as 160 proof ethanol in certain cases. It burns cooler than pure Ethanol but it has even less energy density. The goal in that case would either be to run in a special high compression engine or to be cheaper than making pure Ethanol. I've heard it's twice as energy intensive to turn 190 proof into 200 proof but I haven't verified it. But I believe that is why Brazil uses ethanol will a little bit of water left in it.
Originally Posted by drainoil View Post
Corn gas certainly has a following in the the hi-po world.
Gas Versus E85 - Converting To Corn - Popular Hot Rodding Magazine
Allch Chcar, I checked with my uncle just for you and he confirmed he put the lid on his mason jar, and screwed it tight to keep air out.
I'm sorry for the confusion. Current Gasoline starts to go bad in about 3-4 weeks.
-Allch Chcar
The Following User Says Thank You to Allch Chcar For This Useful Post:
WesternStarSCR (12-07-2012)
