Originally Posted by ron
something to look into that air lowering at speed .I plan on replacing all 4 shocks come spring, I wonder if an aftermarket air shock mfg has anything like this yet and if so at what cost
Originally Posted by Sven7
Just for the record I would not wish that air suspension kit on my worst enemy, and a kit from a infinately more reputable company is only slightly more expensive.
RideTech
However both of those are full air ride kits. But if you really wanted to make this work you could probably do a static drop which would cost significantly less and then augment it with air shocks or helper bags, so you would have the ability to lift it back up close to stock height whenever you want and lower it for interstate speeds or loading. Although a setup like that still might run you like $600~$800.
