Old 12-07-2012, 12:26 PM   #29 (permalink)
RatherDashing
alrighty. well ill have to look around locally see if i can find the pcv valve and grommet. none of the autozones around here carry it. im actually in the middle of an oil change right now letting the oil drain out. i decided to take another look at the IACV. the shop said they cleaned it out. i dont see how they did because the two parts where the hoses connect to the valve are beyond stuck on there and definetely look aged on there. HOPEFULLY when i get this thing off and do a more thourough cleaning of it my major idle problems will be fixed. also cleaned out the throttle plate which was quite dirty. i think i see what your talking about with the tin box. thankgod im skinny as hell to be able to reach in there.
