Old 12-07-2012, 10:45 PM   #15 (permalink)
ECONORAM
halos.com
ECONORAM - '07 Dodge RAM 1500 QC SLT flex-fuel
90 day: 18.16 mpg (US)
the Avenger - '08 Dodge Avenger SXT
90 day: 27.06 mpg (US)
Send a message via Yahoo to ECONORAM
Originally Posted by RobertISaar View Post
certain cars have a ventilation system that forces air through it due to high pressure zones on the blower intake area, so the faster you go, the more air gets forced through it with the blower not contributing to the airflow. if you have the position selector set to move air through dash vents, go 50MPH or so with the blower motor off and see if you can feel air movement. if so, it won't be much, but it will be something.
others have a completely "sealed" system that has absolutely no airflow with the blower off.
others yet have systems where the blower motor is on at all times, although at a very low speed to where you usually won't be able to hear it.
it's all dependant on how your HVAC system was designed.
I agree, the HVAC design plays a role. My truck's heater core gets hot coolant all the time?! Yes, even in summer. I installed a bypass valve so I can shut it off in summer if I want to. Haven't thought to test it and see if anything changes...might check yours.
