Old 12-08-2012, 01:50 AM   #3 (permalink)
bondvagabond
vandle - '93 Ford E-350 Xlt
here is some hard numbers to help the physicists help me.
Engine 6 Cylinder Diesel OM 621 190Dc:
Capacity: 1988cc 121.27ci
Type: Diesel, watercooled four stroke, reciprocating piston type with 6 cylinders
Configuration: Front mounted, longitudinal, inline
Head: Pushrod and rocker actuated ohv with one valve per cylinder
Fuel System: Bosch injection pump (pre-combustion chamber)
Bore and Stroke: 3.43 x 3.29 inches (87 x 83.6mm)
Power: 55 hp (DIN) @ 4200rpm
Torque: 11.5 mkg @ 2400rpm (87.0 ft/lb)
Compression Ratio: 21.0:1
2007 Silverado 3500 classic duramax diesel, Allison 6 speed auto, extracab long bed. Doing head gaskets, will probably do econo tune and aero mods next.
Mad max would have driven a metro
