Yes, and no. I can tack pieces together and do some functional (read: not pretty) longer beads. Just need more practice. That is the rough idea, the wood I was talking about would be the anchoring using the factory mounting holes. Chicken wire would work too, but I already have wood, various sizes of steel rod, resin and small amounts of fiberglass mat. So I'm thinking between the wire and fleece for the shape, with fiberglass support it will be strong enough.
It might help if I draw this out, I know I'm not the best at describing things.
