Old 12-08-2012, 10:52 PM   #10 (permalink)
order99
order99's Avatar
When i'm not obsessing over my 93 Festiva or attempting to upgrade my employment status to something resembling 'Stable', I build homemade guitars and Ukuleles out of cigar boxes, tennis rackets, cookie tins etc (teaching myself to PLAY them is another matter entirely as my neighbors and their pets can attest... ) Of course these instruments are of rather..unique measurements and don't fit into any standard case or gig bag.
The solution? My local music store throws away the shipping boxes whenever the new stock comes in, and with permission I nick a few. After using a razor blade and stapler to chop down or expand the box to fit its instrument, a thin layer of polyester resin (left over from last year's bodywork on the Festiva) seals and hardens the cardboard. Thin strips of bent cardstock can be epoxied into reinforcing ribs if needed for almost no extra weight-then the outside is covered in thin cloth (usually some leftover worn out T-shirts or a former summer curtain) and wetted. One the top and bottom are finished, holes are drilled for two surplus belts-the buckles for fasteners and the rest for leather hinges-the results are plain but functional, lightweight and strong.
Last month I was asked to make and ship a cookie-tin Tenor banjo cross-country, so after making a case for it using the techniques listed above, I glued in the foam I wanted for travel-then filled the box with 10 lbs of old cans and taped an egg in each corner. I then proceeded to climb to the top of my barn and toss the package 30 feet to the asphalt road below.
Result? Minor scuff on the case, three unbroken eggs. I packed the banjo and mailed it with complete confidence, and had an omelet for lunch.
If I can ever get this property sold and move out to the coast, i'm considering prototyping a boat out this stuff-with more layers and greater thicknesses of course...
