try using thin lauan plywood 1/8 in thick in several layers (3) 1st layer flex to desired shape ,apply glue 2nd layer is applied then the 3rd glued when the glue cures the lamination will hold the shape its cheep, lite weight and can be fiberglassed should come out about 1/2 in thick. good luck
