Old 12-09-2012, 09:52 PM   #66 (permalink)
user removed
Originally Posted by Texasc1985 View Post
Your camper looks great. What kind of sheathing did you use?
Another easy way to squeeze more mpg is to advance the timing. On engines with an actually distributor I would advance them until it dieseled after the ignition shut off and move it back 2-5 degrees.
If the truck has an OBD-II (post 1997 vehicles) Bully Dog Tuner set at 87 octane and reset the timing 2 degrees or so.
2012 Nissan Frontier 4.0 V6 - pre mod 19.6 mpg, last tank 23.25 mpg and current tank with timing adjustment is at 30 mpg on scanner.
The sheathing is from home depot. It's a prefabricated fiberglass panel with the color imbedded (white). Not cheap at just under $35 for a 4X8 sheet but I don't need to do any further finishing to the panels. I put the textured side on the inside with the smooth side out, whic is the opposite of the way it was designed for use in the home.
regards
Mech
ron (12-09-2012)
