Old 12-11-2012, 08:28 AM   #4 (permalink)
Daox
Depending on the vehicle you're thinking of putting it in, a couple inches can mean it fits or not. It also has a fairly large effect on torque output of the motor if you're going to be picky at all about that. Going from 10" to 12" gives you 20% more torque at the same RPM. Of course at the same voltage, you loose 20% of your peak RPM.
