Originally Posted by dcb
Why do we care if the zener stabilizes? Is it causing greater than 5v spikes on the atmega (can you scope on the chip?) Would a smaller resistor better protect the chip? And why do you think the zener is reverse biased during the inductive spike?
Well the concern would be solely its high being near the slicer threshold of a 1 versus 0.
Zener diodes are reverse biased by design to operate in the "zener" breakdown region.
Data Point 1992 honda civic cx
#define vssPulsesPerMile 4100ul
MPH was within 2-3 of the gauge cluster. More fine tuning could be done to match them exactly. I'm not running OEM tires so I will probably do that calibration with a GPS unit. I thought of a neat feature to add to the program : basically something that would compensate for different size (diameter) tires than OEM.
I can hook a scope up to the car, what would you like to see?
