Thread: Newbie from DFW
Old 12-12-2012, 07:52 PM   #2 (permalink)
slowmover
90 day: 19.36 mpg (US)
As a Dallas native, welcome. Moved away a few years ago and miss some of the techs and shops where I knew I could find good work and great advice.
What has worked well for me is:
1] Combine all trips. The DHS sez 90% of us go to 90% of the same places 90% of the time. I used MAPQUEST "Best Order Routing" to analyze my usual errands. It is one thing to know to go to the farthest place first (via freeway if possible for a long easy warmup), but it is another to find right-turn only routing from thereon (as does FED-EX and UPS). The effort is worth it.
2] Now, having eliminated short trips and cold starts, the challenge is to drive the remaining miles as well as possible. I decided that changing my habits was crucial as I wanted things to be habitual. That is, I would use whatever methods adapted on a constant basis. It isn't enough to know how to do EOC or P&G, but that one must make them part of the routine of driving.
I've been driving for economy for 40-years, but that didn't mean that there wasn't room for improvement. Just beating EPA estimates is not hard (but it was enough for me for many years).
I highly recommend extensive records. The fuel log here is good to use. I record in a journal kept in the console. All gallons, and all miles. Any effort expended is all about changes to the baseline mpg: the percentage change.
Finally, it is worth every effort to mechanically baseline the vehicle. Don't assume that alignment or brake drag or steering wander, etc, is within boundaries, Spend a little to find out. Little things like posture, mirror adjustment, clean glass all add up.
FE is all about details. Many, if not most, are just a matter of making some lists (scheduled maintenance as a beginning) and checking things off as part of those records.
A big metro area presents challenges. Time and distance don't always equate as stress plays a big role in getting from Point A to Point B. The relaxed driver who has to give the least input to the vehicle to maintain best momentum is miles ahead.
Good luck.
The Following User Says Thank You to slowmover For This Useful Post:
Runum (12-12-2012)
