Old 12-12-2012, 10:18 PM   #23 (permalink)
serialk11r
Going from 45 (2500rpm) to 55 (3000rpm) results in a cruising gas mileage drop from 48 to 38 - that's almost a perfectly linear drop, 21% less FE at 22% higher speed. From 55 to 65mph I go from 38 to 32, which is an 18% drop at 19% higher speed. My gas mileage remains around 48 from 45mph down to about 20mph.
Swapping out my transmission for one from an Integra LS would allow me to go ~21% faster at the same RPM in 5th, or cruise at the same speed with 17.5% lower RPM. Another way of looking at it, I could do 56mph at the same RPM I run now at 45mph.
I think that's about the same as my car. Might've been a very slight downhill grade, but 26.x mph (1500rpm ish) was 55mpg, 45mph (2500rpm) is like 48, 55mph (3000rpm) is like 38, and 70mph (3800ish) was like 30? 32? something like that.
Swapping out my transmission for the base Corolla transmission would get me about 10% lower final drive and 10% lower 5th gear for ~20% less revs at the same speed. Getting a 6 speed C60 would either get me ~5% higher revs (Lotus Elise has the same ratio for 6 as my 5, but they have bigger tires so their highway rpms are actually something like 2% lower!), or it would have the 6th gear that gives 10% less revs, but C60s run 2000 dollars or something like that. My standards for quietness and comfort have dropped to the point where I would be extremely happy to have just the 5th gear changed and be able to do 55mph at 2700rpm instead of 3000. Pretty big difference in noise.
If a girl complains about the noise, gonna order a new gearset immediately, Until then, I'll just try to think about all the gas I'm saving on 25mph roads by being able to use 1500rpm instead of 1800 and try to forget the extra gas that's disappearing on the highway >_>
Originally Posted by arcosine View Post
.68 gal/hr @ 2400 rpm @ 76 mph = 111 mpg
Nice! The 1ZZ idles at 0.22 gal/hr I think, about 680rpm. Unfortunately, 70mph=3800rpm so I'm guessing 3800rpm no load would be well over 1 gal/hr.
