Old 12-13-2012, 07:10 AM   #78 (permalink)
sendler
sendler's Avatar
90 day: 105.14 mpg (US)
90 day: 60.68 mpg (US)
90 day: 38.51 mpg (US)
PCX153 - '13 Honda PCX150
90 day: 104.48 mpg (US)
90 day: 80.94 mpg (US)
90 day: 72.57 mpg (US)
The best streamlining might get an electric motorcycle up to a top speed of 75 mph without adding a transmission. And get it down to 90 Watt hours per mile of consumption at 65 mph/ 105kph. A 72v 100ah would be difficult to fit. The A123 Amp20 pouch cells clones are the best right now and being sold direct from China for 1/3 the retail price. $25 each in quantity. $2200 for the cells at the wholesale price. The finished size would be two rows of 240mm x 180mm x 320mm and weigh 100 pounds / 45kg. You don't want to carry it around and it barely fits. A similar battery from GBS cells would be much larger due to the nice cases and cost $4000 with a monitoring system and charger. These cutting edge batteries would provide a usable range of 60 miles/ 100km at 65mph using a gentle 80% of the capacity and charge in 5 hours from a normal 110v USA electrical outlet for $.80 . With perfect care the A123 cells should retain 80% of their original capacity after 3000 cycles.
I am starting a new project for an e-bicycle conversion using a hub motor at 72v/ 20ah on a fully faired recumbent. My goal is 40.40.40.
40 mph average speed, 40 mile range, 40Wh per mile.
Actually, I will need to hit 30Wh per mile to make it to work without adding a second, $700 pack which might mean an average speed of 35mph. I bought the bike and it will be easy to streamline with an oval bubble for the nose and a fabric body back to the tail.
The Following User Says Thank You to sendler For This Useful Post:
renault_megane_dci (12-13-2012)
